it is possible to rebore a 3.4 to 3.8 ? and if yes,what other things i should get besides new pistons??
is it possible??
Re: is it possible??
no, you cannot bore that block out, it is basically at its maximum safest bore already
and for an overbore, you only really need new pistons, rings, and a bigger head gasket (although most of the time they are already oversized)
Originally posted by Rob Bell View PostJust curious, isn't the 3.4 based off the 2.8 block? So we've got 2.8, 3.1 and 3.4 all from the same block?
From what ive read yea thats what they did. Just kept borin it out and the last time made it the 3.4l1994 3.4L DSG Camaro
Comp Cam 260h w/ 1.6 rockers, J&M STB, UMI 3pt SFC's, Spohn RCA's + Adj. PHR, KYB AGX Shocks, PS Headers, Cutout, Posi Rear w/3.42's, Aluminum DS, Wings West Body Kit, SS Hood/Spoiler, 17" TT2's 9.5/11" 275/315's, 5% tint
the 3.8L is an entirely different block
it is probably possible to stroke it to 3.8l, but it would require a ton of block work, there is NO WAY the cylinders could be bored ~.20 over... SBC blocks have a hard time with .060 over, in order for an overbore, that 3.4 block would need to be bored over 3 times that, not to be mentioned would also need a (probably) custom crank
doing so would greatly affect the integerty of the block.. not to mention the cylinder walls would overlap
so purchase a 3.8 block, you can get them a dime a dozen..
ArcherMISC: 01 parts. Some interior, T top kit, seats etc.
http://forum.camarov6.com/showthread.php?t=95347
he coiuld try overboring & sleeve it, but it might be cheaper to get the goodwrench aluminum block (if it's even still made).
While I haven't perused the forced fed forums, take a look at what they've done for more power, and even look at what Tiago's set up was (the infamous forced fab iirc)1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
