Having a valve job done. Also having heads resurfaced due to excessive heat from LIM leak. Will it affect my valvetrain geometry, and can I use the stock pushrods?
pushrod question
Re: pushrod question
Just get the heads milled .005 or .010 and use stock gaskets you shouldn't have a problem using stock pushrods.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
