So I went ahead and ordered some 1.7 crane gold rocker arms from ftpp.net. Since most say the stock ratio is around 1.7. These are stud mounted with roller tip, just thought it would be nice to get some nice rockers. With my VS cam it would put my lifts at .544 intake and .538 exhaust, but I'm running ZZP's modded steel retainers and Viton guides that say will give me an extra .050 clearance. I also self ported/polished the heads and had a valve job done with stock size SI valves. Any one else have any experience with these rocker arms?
Re: 1.7 crane gold rocker arms
I think thats what I'll do is try them out when the new heads go on, I did the P/P and had the valve job done and the 105lb springs hold up to .600 lift so I think I'll gain a little more through the rpms , since I only shift it at 6000 rpms.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
FTPP.net just raised the price from 298.00 to 399.00 on these rocker arms, from the last time I looked on their website, which was Sunday. So either they were priced wrong or they had alot of people ordering them and raised the price.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
what is the part number on them? I can see if the price went up recently.
Probably had an old price and never updated their site until you ordered them, lol
The part # is 144750-12 1.7 Crane gold rocker arms,they were 303.53 when I bought them on 9-26, now their 399.99. LOL I gues they didn't update their page then. I'm not complaining, but they better send them out to me.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
yea, according to my wholesaler they are not any higher than before. Maybe their supplier up'd their pricing
I had some light weight pushrods from intense and when I swapped them out after 5 years , I think 8 out of 12 were bent or warped. Meatyshells and I then put in Comp 5/16 pushrods ,Comp 105 springs and ZZP steel modded retainers in(him doing most of the work,thanks again Ryan). The car felt totally different , car pulled harder and just felt alot better. If your going to be adding a power adder or reving high I wouldn't go with lightweight pushrods. If your cammed I would def. not do lightweight pushrods, this is just from my experience with them.Last edited by ssms5411; 10-01-2008, 06:47 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Looks like Ftpp.net has to contact Crane to see if I can use our 5/16 rocker arm bolts with them, they use a 3/8 bolt. They said the pushrod side can take up to a 3/8 pushrod, so will see what they say . I think they will be refunding my money because everything I read seems to lean toward they use a 3/8 rocker bolt. I'll post when I here anything else.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by vr4gasm View Postmake them refund you the NEW pirce due to your trouble? haha worth a shot eh?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I don't believe those were ever meant for use on the 3.8, I believe those are 3.4 only
scratch that, THOSE particular rockers are meant for an LS1, they are not interchangeable. The 3.4 gold rockers have been around for some time.Last edited by black98V6; 10-06-2008, 05:38 PM.-Brad
2000 V-Star Custom 1100
:rock:
