So, I am finally ready I think to start gathering the parts for my head/cam/intake work. I doubt the cam will get done this year though...maybe next winter...
I figure that this winter I want to install heads, and ported upper and lower intake manifolds.
my question is, of the work that I need to do to install the heads/intakes, what will I have to go over and redo when I go to put the cam in a year from now?
I.e. will I have to pull off the intakes to put the cam in?
also, if I just install P&P heads/intakes right now, will I need to tune?
I am probably going to put in 105# springs also, so will I need a double roller timing chain now, or just when I get the cam?
I can't afford to do everything all at once, so I figured I should do the heads/intakes first because I am going to need things like stiffer springs/retainers in order to run the cam....also, I know I have to take off the intakes to get the heads out....
