cam swap - FirebirdV6.com/CamaroV6.com Message Board
cam swap
  • cam swap
    Hey guys...I know there are a couple of these lists, but opinions and knowledge changes so I just want to confirm I have everything on this check list that I will need for a Cam swap into my 1996 camaro.
    Cam: ARH Naturally Aspirated cam -210/220 @ .050 -.320 lobe lift on the exhaust, .512 with a 1.6 rocker ratio-112 lobe separation
    http://www.abbottracingheads.com/gm3800.htm
    Single roller timing chain- Apparently these break at 40.4kn and our stock ones break at 16.9kn?
    http://intense-racing.com/Merchant2/...egory_Code=HCV
    Seals-
    http://www.zzperformance.com/grand_p...=125&catid=104
    retainers
    Ls6 springs- http://intense-racing.com/Merchant2/...egory_Code=HCV
    or
    105# Springs- http://intense-racing.com/Merchant2/...egory_Code=HCV
    lifters-
    http://www.zzperformance.com/grand_p...=109&catid=104
    cam install kit- http://intense-racing.com/Merchant2/...egory_Code=HCV
    GTP 36# injectors
    Wideband O2 and controller
    Hp Tuners.
    Cam and crank bolts
    Is there anything I am missing? any suggestions?
    Re: cam swap
    cam and crank bolts need to be replaced and go with 105 springs. Make sure that installing kit comes with the gaskets for your car because intense is front wheel drive 3800 supplier. You might just want to call abbotts and ask them for every gasket to change out a cam like I did. And you need a PCM from a 1997 car because your 1996 cant be tuned with HTP.
      Re: cam swap
      I already have a 97 pcm in there....ok so aside from the gaskets (i'll have to contact abbott)...everything else look ok?
        Re: cam swap
        ya I have all my cam stuff ready to go aswell. I'm going to start mine as soon as the semester ends. Sounds like you have everything if not I'll chime back in ooo hows your tool situation?
        Edit: you need moded retainers for your new springs zzp sells them.
          Re: cam swap
          I wanna start mine at the end of the semester in about 1.5 weeks lol...but looks Like I will just begin ordering parts then...Not sure about the tools yet...I know I need a valve spring compressor, and a special tool to remove fuel lines...other then that I got some gear wrenches I can borrow and a compressor as well
            Re: cam swap
            well I got everything on your list now besides the injectors stupid 00+ fuel rails- looking for trailblazer injector right now off a 4.3 but looks like I'll need to buy 1998 and older rails. While your in there you might as well get harden push rods just to be safe.
              Re: cam swap
              I was contemplating them, I heard they bend easy though...what size do we need do you know?
                Re: cam swap
                ummm I have never heard of them bending? if anything they would be better than stock, I would just get stock length, not to sure on size though. I have not ordered new push-rods yet.
                  Re: cam swap
                  If you're upgrading pushrods, get some Comp Hardened 7.05 pushrods. They're much stronger than stock. Only the lightweight pushrods bend under high load.
                    Re: cam swap
                    might as well do pushrods also
                      Re: cam swap
                      getting new/hardened pushrods "just to be safe" is like saying "wear elbow and knee pads when you ride your bike;" you're not in that much danger to begin with, and if you are in a situation where you'll need such protective measures, you're probably doing/did something wrong.
                        Re: cam swap
                        Do I need to get new valve cover gaskets or can I reuse mine? I just replaced them about a month or so ago....
                          Re: cam swap
                          as long as you don't trash them during the install, they'll be ok to reuse
                            Re: cam swap
                            you might want to get new valve locks, i know its very easy to drop and loose some
                              Re: cam swap
                              meaty...I know you had some trouble installing retainers or something with the heads in when you did your swap...what exactly did you have a problem with, and what did you do when you had the heads in the car to get around it?
