Hey guys...I know there are a couple of these lists, but opinions and knowledge changes so I just want to confirm I have everything on this check list that I will need for a Cam swap into my 1996 camaro.
Cam: ARH Naturally Aspirated cam -210/220 @ .050 -.320 lobe lift on the exhaust, .512 with a 1.6 rocker ratio-112 lobe separation
http://www.abbottracingheads.com/gm3800.htm
Single roller timing chain- Apparently these break at 40.4kn and our stock ones break at 16.9kn?
http://intense-racing.com/Merchant2/...egory_Code=HCV
Seals- http://www.zzperformance.com/grand_p...=125&catid=104
retainers
Ls6 springs- http://intense-racing.com/Merchant2/...egory_Code=HCV
or
105# Springs- http://intense-racing.com/Merchant2/...egory_Code=HCV
lifters- http://www.zzperformance.com/grand_p...=109&catid=104
cam install kit- http://intense-racing.com/Merchant2/...egory_Code=HCV
GTP 36# injectors
Wideband O2 and controller
Hp Tuners.
Cam and crank bolts
Is there anything I am missing? any suggestions?
retainers
or
GTP 36# injectors
Hp Tuners.
Cam and crank bolts
