3.4 Update/question - FirebirdV6.com/CamaroV6.com Message Board
3.4 Update/question
  • 3.4 Update/question
    Well, the car is all put back together, but misses very badly under accelaration. I double checked the spark plug routing and tested the secondary resistance on the coil packs and they were all fine.
    Strangely, today I moved it when I got home from work and it started up fine, no miss ! I drove it around the block and for the first few minutes, it drove great and by the time I got home it started missing and hesitating again.
    Any ideas/suggestions ? I am leaning towards a coil pack, but don't want to just replace random parts, that gets expensive. Not sure if it's of any significance, but the temp. did drop tonite.
    Thanks in advance.
    Re: 3.4 Update/question
    if you know it's not the plugs and wires then i'd go ahead and replace the coil packs, or at least buy one good one and replace them one at a time to see which one is defective, usually it's only one causing a problem. You may also want to replace the ICM while your down there just to be sure, you can't get one of those on ebay for around 40$.
      Thanks, I will give that a shot.
