removing main caps 3800 - FirebirdV6.com/CamaroV6.com Message Board
  • removing main caps 3800
    As some of you know our main caps on the 3800 are pressed in. I am having trouble getting them back out. My Haynes manual recommends using an adapter plate that bolts to the cap allowing a slide hammer to hook up to it that is available at most parts stores. All of the parts stores I have been to dont have it. Does anyone know where to get one of these specialty tools? Or should I thread the cap bolt holes so I can bolt my own plate to it?
    Re: removing main caps 3800
    i would also like to know this....pulling the motor on mine for a rebuild also...
    99 Z28 M6...91 Z28 A4...84 Z28 A4
      Got them off last night. I dropped a couple of big bolts into the main cap bolt holes, and c-clamped them together real tight so they wedged themselves in there. I then hooked a slide hammer to the c-clamp and they came out pretty easily.
        Imma check an see if I can get it here cuz I got everything out...got one of the main caps off with a little hammer/screwdriver work but the others there really isnt any way to get them out that I can see???
        Anyone know who has this special adapter plate?
          Lol after I made that post I went outside and got hem off in less than 15 minutes with a 2x4, a rag, a screwdriver, and a mallet.
