what would i have to do to change a v6 92 auto to a 305? and how hard would it be?
swapping v6 92 auto with 305
Re: swapping v6 92 auto with 305
complete engine, nothin swaps over from the 6 to the 8.
need a diffrent trans too.
and mounts
some people say "you have to swap springs,rear, yadda yadda" i've never changed springs or rear. its a more if you have the money and want to.. dont have to, to get the car driving.
easiest to find a pull out.
and forget the 305.. if you can find one complete for CHEAP and its complete with ALL the brackets for an F-body.. if you can, grab it for that stuff. but save yourself the dissapointment and just get a 350. 305 accesories bolt up no problem to a 350(its all the same for the most part)
