Ok to make a long story shot, i had a motor swapped into my car. The motor that was in it had a gt2 cam in it, and i told the mechanic to swap it over. He calls me and tells me that he swapped the new motor in and didnt put the cam in because "it was messed up". I picked the cam up, and honestly think its fine. What do you guys think? You can see a couple small scuffs, and it looks like some circular marks (these marks do not even catc a fingernail and it feels smooth to rub over it.) Either way, heres some pics let me know what you think.
cam damage
Re: cam damage
dont new cams have to have a breakin, like upon start up immediately bring the motor up to like 3000 rpms...Team NoVa
Re: cam damage
Originally posted by flamingchicken View Postdont new cams have to have a breakin, like upon start up immediately bring the motor up to like 3000 rpms...
and its between 1500-2000rpm for 15min
edit* and thats just for the lobes so they can wear properly.. those pics indicate something happened to the cam journalsLast edited by cam98aro; 01-08-2009, 04:06 PM.
Re: cam damage
nother q, do our cars have roller or flat tappet?Team NoVa
Re: cam damage
just for some info, there is basically 4 types of cams.. 2 groups, flat tappet, and roller, and each type can be either hydraulic (which is basically a spring in the lifter that pumps up at higher rpm, letting the car have lower lift/duration at lower rpms) and solid (which the lifter is basically a hunk of metal with oil holes drilled through it.. you will get the same lift/duration at all rpms, unless the cam is designed to launch the lifter off of the lobes)
Originally posted by lilchubby View Postroller...........
took it to the speed/machine shop. The guy said its not that bad at all (maybe the pics make it look worse then it is). he is going to polish it up and said it should be perfectly fine to use.
Re: cam damage
[QUOTE=cam98aro;899543
[/QUOTE]
Also the hydraulic lifters allow lash. ie- with solid lifters there is a need to set valve lash for expanding metal as the motor heats up.Team NoVa
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....3 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.3 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
