Does anyone know where I may be able to find Yella Street Terra roller rockers at? I see the terras all day, but I hear they have a less expensive "Street Terra" that's primarily just to get rid of friction and pressure on the valve guides when running taller cams. Thanks to any with any info.
Rocker Question
Re: Rocker Question
http://intense-racing.com/Merchant2/...egory_Code=HCV
These are the rockers I bought. In their description it has something pertaining to what you seem to want..
"-- Reduced Valve Guide & Seat Wear
The traditional metal tip on standard rockers literally drags across the valve tip as the rocker opens and closes causing high side loading on the valve. This inside force leads to irregular and rapid valve, valve guide and valve seat wear in many engines. The roller tip on Yella Terra roller rockers eliminates this side loading action, as a result engines rev quicker and freer with a crisper exhaust note and maintain efficiency longer."
I've been running my 1.7's on a stock cam, 105 comp springs, and a turbo with no problems at all. I'm thinking about getting some for my daily driver too.
TEAM C6V6
Re: Rocker Question
Intense racing has them I think or they did.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Rocker Question
Nice reply at the same time.LOL08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Rocker Question
Originally posted by bigbrian442 View Post
TEAM C6V6
