Pulled an Engine!! - FirebirdV6.com/CamaroV6.com Message Board
Pulled an Engine!!
  • Pulled an Engine!!
    Man all that hell for this little block... Good quality time with the dad on this proj. THAT WAS A TIGHT PULL. from the top in a cramped garage, but now that the car is in the driveway, we have plenty of room:banana:
    Re: Pulled an Engine!!
    should have taken it through the bottom
    2001 Camaro 3.8 A4
    1991 3000GT VR4
    2001 Mitsubishi Eclipse GS
      couldent, we had to roll the car outside to have enough space to work on the engine
        why did you pull the block in the first place? i cant remember
        also harbor freight tools FTW.. well, the engine lift anyways, their engine stands seem very weak
          Looking good. Are you going to rebuild and modify or put in something else? And x2 FTW for the Harbor Freight engine hoist. And cam98maro, I've got 350 from a 79 C3 on a Harbor Freight engine stand that says otherwise.
            Congrats.
            New project: Work on re-sizing pictures. They are huge!
              i have a 327 on one of their stands, and the engine sags down at the front, i have to lift the front of the block up to get the little pin in to keep it from rotating
