Balance shaft - FirebirdV6.com/CamaroV6.com Message Board
Balance shaft
  • #16
    Re: Balance shaft
    i think im going to do that.
    Team NoVa
    • #17
      Re: Balance shaft
      The motor I'm doing has the balance shaft removed and I've used a threaded plug behind the front of the motor, where the oil feed to the shaft is. Had to, running the double roller. There is a thread that kind of shows where the hole is. You can see it off to the side of the shaft from the front. It really sounds more complicated than it really is. I can't remember what the thread ID is though. Apologies.
      • #18
        Re: Balance shaft
        just take the grear off, did it on shodowns car can't even tell... (stock cam)
        if you have a cam you won't notice anyway
        www.turbov6camaro.com
        1997 3800 Series II Camaro
