Hey everyone, I'm putting 1.6 harland sharp aluminum rollers in my 96 3.8l right now. I dont know if there are any adjustments or clearences that should made when installing the rockers. If there is anything I should watch out for or check let me know. Thanks a lot!
Rocker question
Re: Rocker question
Need to have new rocker bolts or reusable rocker arm bolts and torque them down right. You know our stock rockers are rated at 1.6 to 1.66 and some have said 1.7 ratio. But the Harland will weigh a few grams less and look good when the valve covers are off. Just make sure you torque the rocker arm bolts down right to spec. So you don't hear noises when driving.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Rocker question
If there like stock , they should be self alligning rocker arms.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
