i'm going to port some heads for my 3.8 and i wanted to know if i there was a difference between the fwd and rwd heads. i thought i read that there was a difference a while back. thanks
heads
Re: heads
I believe the difference is that the fwd cars have the injectors in the heads...where as we dont.
Re: heads
l67 heads are different. so if they are off a sc car then yes they are different
Re: heads
I thought even the heads not off the s/c cars (like bonneviles and lesabres) are also different no?
Re: heads
I know up to 03' Buick lasabres are the same , because Meatyshells used the buick engine and heads for his car.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: heads
Originally posted by ssms5411 View PostI know up to 03' Buick lasabres are the same , because Meatyshells used the buick engine and heads for his car.
Re: heads
Buick is FWD so you cant use LIM or UIM just the heads ,block, everything has to be switch over ,oil pan , oil filter, and intakes etc.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: heads
Originally posted by LETZRIDE View PostI believe the difference is that the fwd cars have the injectors in the heads...where as we dont.'99 Mountaineer AWD 5.0 - 4300K HID, Some Bolt-ons
'97 RS - HPTuner, Bolt-ons
'09 WRX - Aesthetic mods
Re: heads
Originally posted by Mr. Logger View PostI believe that is the L67 heads you are describing.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: heads
so the N/A l36 heads are ok then? interesting...
Re: heads
any 3800 II or III NA heas are the same
all SC L67 or L32 head has the injectors bosses in the head, I'm not sure if you can plug the hole or not and use them (they will bolt to he block but no sure about intakes
any 3800 II or III block will work in a RWD carwww.turbov6camaro.com
1997 3800 Series II Camaro
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....2 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.2 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
