I’m done with all the boltons, I think
Headers
Cat back
16o thermo
Air intake
3:73 rear end gears
Hp tuning
Is there anything else I’m missing (need) before I proceed to install a cam??
I want to install a cam but I don’t know what kind
I also want to know what else is nedded for this to work the best
Any help will do guys
BTW my budget is around $1200
Well this is the cam im incline for
Comp Cams Xtreme Energy L36 Cam 2. From 3800performance.com
I will also get the Cam Kit
A mechanic close home will do the job for $400. I think that sounds reasonable.
What do you guys think???
headers, high flow cat, slp loudmouth
powerdyne supercharger 6psi
GT2 cam. all done by myself :banana:
Hell yea
If I wasn't so persistent to do everything to my own car, yeah I would pay 400 for someone to install a cam.
I will like to do this job myslef, but im afraid i might screw something up lol
i have all the tools and i know about engines
overall how hard is to install a cam???
Hell yea
the only real part is linein up the timing dots and remove the cam and NOT turning the motor over....
install the cam and timing set then turn motor over 2 times it should line back up
That'd be too easy, and how accomplished would you feel when ya get it done? I've successfully changed a timing chain by just winging it. Don't wing this though, learn about degreeing and just go at it. Double check everything before you put all your covers back on and fire it up.
**** it im doing it myself hope everything goes well lol
Thank you guys
Hell yea
