has anyone made a how to video or sticky on swapping out a cam on a 3.8?
cam swap
Re: cam swap
Originally posted by fatcat View PostAre there any pics? Why do you have to remove the heads? I just want to change the cam, not rebuild the motor?
you dont need to remove the heads to do that
you basically need to remove the intake, the front of the engine (all of the accessories) the timing chain/oil pump, and loosen the rockers to remove the pushrods/lifters
you dont even need to remove the rockers
Re: cam swap
Haines manual explains everything pretty well... You do need to remove the rockers (technically speaking) since you need to change the bolts as they are tty...I suppose you can leave them sitting there though with the new bolts....they'll fall out of place if there is nothing holding them there though, and you might loose them, so I would just take them off....makes life easy...especially since 9/10 your going to need to replace your valvesprings for a cam swap and they will get in the way of the spring compressor.
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....2 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.2 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
