Dual remote oil filters - FirebirdV6.com/CamaroV6.com Message Board
  • Dual remote oil filters
    What do you guys think of dual remote oil filters since I'm going with a turbo I can mount the filters away from the ebgine where they get fresh air and the filtering would be outstanding using 2 long filters like PF52 I think they are and add 5.5 qts. of 20/w50 of Royal Purple. the kit is about $60. I think it would be worth it since I will be turboed. Anyone else try it? I knnow IGORA has done it on FTV6, but was wondering if anyone here has. i have the oil PSI kit to raise the Oil PSI to 80 PSI so the turbo is always getting a good flow of oil to it, even though it only uses a .035 restrictor since it is water cooled also, and doesn't need alot of oil going through it. Any thoughts?
    Re: Dual remote oil filters
    on old vw's they didnt come with filters, just an oil screen, so i put a remote mount fram HP1 on it when i turboed. i also added a remote mount oil cooler since i had the lines leaving the engine. imo one filter should be enough, as long as its a good one. the oil cooler seemed to be a good idea when i did mine.
    Team NoVa
      Thanks, I'll look into a oil cooler I use either Bosch extended or A/C Delco extended filters, I think a guy was selling a stock one from a LT1 here local, so I will check it out. It can go next to the tranny cooler. But if the oil filter gets in the way then remote filter here I come.
        your saying that you want to do one remote filter, in addition to your stock one?
        i thought you wanted to do two, in addition to your stock one? fill me in here
        Team NoVa
