engine wont turn - FirebirdV6.com/CamaroV6.com Message Board
engine wont turn
  • #16
    Re: engine wont turn
    Originally posted by flamingchicken View Post
    damn, that sucks, prolly droped a bolt in there.
    cold it be a broken valve???
    headers, high flow cat, slp loudmouth
    powerdyne supercharger 6psi
    GT2 cam. all done by myself :banana:
    Hell yea
    • #17
      damn the bolts on the heads are tight as ****
      Hell yea
      • #18
        the valve could have hit the piston...
        Team NoVa
        • #19
          i hope the cylinder is in good shape. i can easily replace a valve
          Hell yea
          • #20
            well, hope for the best...but if something was bouncing around in there, you may need a new piston and possibly a bore, which means alll new pistons...just hope for the best.
            Team NoVa
            • #21
              this is what happen when i snapped a valve....
              wheres the piston?!?!?
              it was in my oil pan sweet
              • #22
                Yea, Id guess a broken valve too.
                *Matt
                • #23
                  Originally posted by jimmysprinkle View Post
                  Hope it;s not a cylinder issue. Object in combustion chamber = new engine
                  not really
                  if it was severe enough, then he would need new pistons and a bore.. if it wasnt very bad, he could have just punched a hole in the piston
                  • #24
                    damn. i dont have any metal shavings in my oil
                    i will finish up the head removal tomorrow morning
                    Hell yea
                    • #25
                      was your cylinder ok ???
                      Hell yea
                      • #26
                        Thats why I asked about the valve springs... If they look normal
                        then the valve didn't break like meatys. Thats not to say that it
                        didn't come in contact with the piston though.
                        • #27
                          yeap the spring look normal
                          Hell yea
                          • #28
                            this cam install is been a nightmare since day one
                            Hell yea
                            • #29
                              Are you 100% sure you installed them cam right?
                              • #30
                                yes i am, if there is nothing inside the cylinder i will go ahead and remove the front cover
                                Hell yea
