Strangest Rod bearing ordeal I've ever ran into - FirebirdV6.com/CamaroV6.com Message Board
  • Strangest Rod bearing ordeal I've ever ran into
    So..there was a very quiet knock in my engine.
    and not to be one who just says " Eh, I'll wait until it gets worse " I pulled that S.O.B. apart from the bottom end, and behold...Cylinder 3's connecting rod cap was loose. I took it off and the bearings looked as if they had been rubbed down into thin peices of metal. Didn't even have the notches anymore ( They didn't spin either. )
    I removed the rest of the connecting rod caps as well, Rest of them were fine, besides the normal wear and tear of a 150k mile engine...which is pretty good since I have a 220k mile engine. :)
    Measuring the others out with plastigage, I they didn't even need oversized, so I installed them with standard bearings. well Cylinder 3 wants to be a son of a *****.
    I installed a standard bearing on it, once torqued down and everything. I could still push up on the cap and it'd move the cap, rod and piston up a little. I removed that and went and picked up a .010 and .020 oversized bearing. Even the god damned .020 oversized does it, just not as much. The crank itself isn't scarred, or out of round.
    ...The only other size I can go up is .030 but what the hell? could it really have been that bad? Or am I going the wrong direction here? Do I need to get a hold of an undersize? (NAPA has them. =p )
    I'm to the point I just want to be able to drive the damn car back and forth to work. I'm broke as hell, and I can't get more hours at work until I have a vehicle to drive...and no one else can help me family wise or anything.
    Re: Strangest Rod bearing ordeal I've ever ran into
    When you have a bearing failure you need to have the crank machined or replaced. The easy way it to buy a crank kit with bearings from the parts store. You will need to replace the rod too.
      if your engine was knocking that means your bearing WAS spinning
      you are going to need at least a new rod
      can you take a picture of the crank journals?
