I had a bad lifter tick and am in the proces of replacing the cam and lifters. I got the top end apart and pulled out 11 lifters. The bad one sat about 1/8 inch lower in the lifter bore than the others. I was thinking a bad cam lobe along with the lifter. The problem now is the lifter will not come out the top of the lifter bore. I tried lifting, pulling and finally grabbing it with vice grips for a better grip. But it comes up only so far and gets jammed. I am afraid of pulling too hard and damaging the lifter bore if the bottom of the lifter is damaged. The only thing I can think of is to pull it up as I can and hopefully that will be enough to be able to pull the cam out. Once the cam is out I can then try to drop the lifter into the block holding it from the top with a magnet and then try to sneak it out through the cam bore.
Has anyone else experienced this?
Thanks,
Scott
Thanks,
Scott
