Re: Replacing Cam Lifter stuck in Bore what to do?
I might have a slightly used stock cam if you want it. I pulled it out of a 25K motor when I bought it; everything else was in amazing condition. Can't remember if I still have it or not though; I'll dig around if you want.
smart move. Previous owner probably ran it low on oil, smoked the bearings, then the lifter went south. I bet the rest of the bearings are just as bad.
There is some sludge in the motor and the water pump was replaced maybe they overheated it and that set off an unfortunate chain of events. In any event the crank thrust surface is wiped out and the mains are scored, it is all at the machine shop now.
Scott
NICE!!! i burned up mains in my car not a year ago. and not just the other day i was getting on the interstate with my bug and was haulin tail around the on ramp, and starved my pickup tube for oil and burned the center main and spun thrust...i feel your pain.
Team NoVa
Jimmy,
That is interesting, I have never heard of that before. This is a common practice and I my machinest happens to be an expert crank grinder. Id love to see more info or reports on these cranks failing.
In any event if I had to buy a new crank I might as well junk the whole thing. Its barely worth the money that rebuilding this particular motor costs anyway.
