is there a write up on how to do this? im puttin em in a 96 firebird 3.8. i did a search but didnt find anything. ive already started it and have a general idea of what to do but would like a write up in case i get stuck somewhere
installing fuel injectors
Re: installing fuel injectors
theres no write up...the injectors just pull out of the rails...make sure you get the O-rings out to, they sometimes like to get stuck in the rail...make sure your new injectors have both o-rings on each end...put them back in...I think I put some oil on the rings before I reinstalled them...can't quite remember though...
someone correct me if i am wrong but 4 bolts on the fuel rail unbolt those and pry up then it will pop the injectors out and you have to remove the map sensor off the intake manifold to pull the fuel rail out of the car it will not clear with it on.. injector o rings are a must and they arre 17$ from the dealer.2001 Camaro 3.8 A4
1991 3000GT VR4
2001 Mitsubishi Eclipse GS
vr4gasm has it down. 2 bolts on fuel rail on either side of the manifold. Remove map. Pry up. Pull the rail out a bit. Then pop old injectors out, pop new ones in. Add a little vaseline to the o-rings to help them go in.
The only other thing to add is remove the coil packs and the alternator to make more room for yourself if you haven't already done so. :D
aight yeah i pulled the coils and icm did not have to get rid of map sensor just popped the fuel rail off enough to get to the injectors. however three of my injectors are missing the piece to hold the oring in place arrrrg. oreilleys nor autozone had it so i have to check a few places today.sigpic
http://www.fullthrottlev6.com/forums...ight=injectors
maybe a day late and dollar short but there is a really good write up on injector swaps
Originally posted by firebirddrvr View Postaight yeah i pulled the coils and icm did not have to get rid of map sensor just popped the fuel rail off enough to get to the injectors. however three of my injectors are missing the piece to hold the oring in place arrrrg. oreilleys nor autozone had it so i have to check a few places today.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.4 weeks ago
