Various Motor Swap Questions... (3.8 to LSX vs LQX) - FirebirdV6.com/CamaroV6.com Message Board
  • Various Motor Swap Questions... (3.8 to LSX vs LQX)
    I have a 2002 3.8L Firebird - looking for more power.
    I want to stand out from the crowd alittle bit...
    I have a few questions...First the simple stuff...
    1. I would SERIOUSLY like to keep my stock 125 MPH speedometer. It there any way I could have the PCM configured to correctly operate the gauge cluster or MUST I go with the 155 MPH speedometer?
    2. I have heard a few people saying that their A4 Trans from their V6 bolted up JUST FINE to the LSX with no modification required, albeit rather a minority, it could save me alot of money if I could do the same... How would I go about finding out if mine would bolt to the Motor??
    3. I have a Y87, how much power can that Posi Handle because I already have the gears (3.42's) I want.
    Now the more technical questions
    4. The LS1, LQ4, and LQ9 are basically the same bottom end motor, with the exception that the LQX motors have a slightly larger bore and they're made of Iron... The LQX motors I believe are about 200 LB's heavier than the LSX motors if I'm not mistaken, however since they have more displacement, given the same mods, the LQX will make more power. HOWEVER, will it be enough power to overcome the weight difference or should I just aim for the LSX? Reason I'm asking is you can get an LQX motor and transmission for about a grand cheaper than an LSX motor and transmission.
    5. If I do decide to go LQX, what should I look for in terms of my suspension setup on the front?
    6. Once again, on the LQX - Which PCM and Wiring Harness should I use? The one that comes with the LQX motor or the one built for an LSX of my year and model?
    7. With an LQX, can I use the stock accessory belt routing or should I convert it to an LSX setup?
    8. I assume I wont need to do anything fancy to remove the vortec intake and swap in an LS6 / FAST Intake correct?
    9. The 4L80E A4 from the LQX motors, will it bolt up to a 4th gen F-Body and function in my 02 Firebird or will there be modification required?
    Re: Various Motor Swap Questions... (3.8 to LSX vs LQX)
    If you want all gauges to read correctly, then the 155 is a must.
    Someone is lying to you. You need to change things that require complete disassemble of the transmission and parts from a V8 F body trans as well.
    It is the same rear that the V8 cars came with.
    Try about 88 pounds heavier. Yes, they will make more power if you change the heads, cam and intake.
    Change the front springs.
    The one for your year car with a LS1 would be the easiest to adapt.
    No. You will need the accessory's and brackets off of a LS1 F body. The Corvette and truck stuff will not work. This includes the harmonic damper.
    It will just bolt on but you will need brackets and water bypass tubes from a motor with the LS6 intake.
    Modification will be required to the car and PCM.
      Doing the swap into my 96. Quite a bit more difficult. Custom wiring and so on. In terms of weight 88lbs is right. Which you can shave off rather easily. Put headers on will shave 11lb manifolds. Aluminum heads shave the 40 sum odd lbs of iron heads. On top of that I went with tubular solid mounts which spohn said drops another 10. My gauges won't work without a converter box etc etc it's a pain but worth it. Also on the trans you will need a fbody tailshaft for the torque arm mount. Modify the tranny crossmember, ls1 throttle cables. And many more little things I can't remember off the top of my head.
        Almost all LS heads are aluminum, a few truck heads might be iron. The 88 pound difference is from the iron V6 compared to the aluminum block and head LS1. Tom RS did A LS1 conversion to a 97.
        http://forum.camarov6.com/showthread.php?t=95439
          If you want to shave off some weight in the front go with a TUB. K member and tubular lower/upper A arms's, should be worth 40LBS+, also a light weight hood about 20 LBS+. Theirs 60 LBS+ at least right their or more. I run this plus QA-1 Shocks and springs and it raised my V6 front about 1" with also no front bumper support and windsheold resivior and misc. deleted items up front and its about over 120 LBS off the front end, but I'm adding a turbo so I will have about 50-60LBS in turbo stuff back on the front end when I'm done, so basicly I'm saving 60lbs off the front but adding another 150-200 WRHP so it works out pretty well. But I would look into the K and A lower A arms at least their the most heaviest and the front bumper support, TUB upper A arm about a 1-2LB different than stock so not really a big difference. QA-1's are about 7LBS per side so not a huge difference but it starts to add up. I would go with a LSX motor since more parts ready available and cheaper.
            My fiberglass Raptor hood was only 12 pounds lighter then the flat steel hood. That was disappointing.
              my thread has lots of good info in there. All gauges will work fine, you do not need a v8 cluster
              1997 Camaro LS1 RS
              1994 Camaro - Sold
              1999 Trans am Vert - Sold
              A Few Mods....
                That is for a 96 and 97 car. 98 up cars you will need the V8 cluster or the oil pressure and tach will read incorrectly..... Been there.
                  Brian , what years use the Dakota signal adapters? I forget , is it 96-97 years, for the RPMS?
                    not true. You need to re-program the tach output to a 4/4 from the pcm and you need to run a wire from the pcm pin for oil pressure to the gauge.
                    1997 Camaro LS1 RS
                    1994 Camaro - Sold
                    A Few Mods....
                      dont need that if u have a tune or hp tuners
                      1997 Camaro LS1 RS
                      1994 Camaro - Sold
                      A Few Mods....
                        Tach output/resolution/high and Tach output/resolution/low?
                        And for the oil pressure gauge the sweep is off. Running a wire will not help on 98 and up. The gauge works and points where it should if the numbers were in the same spots on both clusters. Unfortunately GM thinks the V6 needs more oil pressure then the 8.
                          yes thats what i did in the pcm. the tach is basically right on. Yes you are right the numbers on the oil pressure are different but the gauge still reads.
                          1997 Camaro LS1 RS
                          1994 Camaro - Sold
                          A Few Mods....
