I tried to search it but got a bunch or random threads. i have read befor on here that inorder to run gtp injectors on a 98+ u need to switch to 95-97 fuel rails?
Gtp injectors on 01. do i need 97-rails?
Re: Gtp injectors on 01. do i need 97-rails?
yea or modify your rail. Also will need different pigtails for the wiring harness
Originally posted by vr4gasm View Postjust use injectors out of a 4.2l straight 6 trailblazer or envoy they are direct plug and go
It also depends on what fuel pressure they run at to calculate what they flow at on ours. Like 36LB Bosch style GTP injectors flow at 33lBS on our F-bodies so I have them scaled from 33.00 to 34.00 on the flow chart.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
