Does anyone know if there is a replacement floor pan for our cars that you can buy? My passenger side floor pan has 3 rusted out holes in it that I need to fix...
Project Cars | How To Guides | Scratch Repair | Synthetic OilTags: None
Re: replacement floor pan
Sure its not from all the power your making and its ripping apart with the 13 sec. slip. J/K, they make sheets of steel you can buy on ebay and the just cut out the sections and have it welded in, I have bought some before for different projects.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostSure its not from all the power your making and its ripping apart with the 13 sec. slip. J/K, they make sheets of steel you can buy on ebay and the just cut out the sections and have it welded in, I have bought some before for different projects.
How big of a spot from rust spot to rust spot, becuase on ebay I got 1ftX1ft metal sheets and they also make them bigger then that. instead of cutting out the whole floor board. Just a thought. Just keep a soft right pedal, pretty soon your windsheild will come off. LOL08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostHow big of a spot from rust spot to rust spot, becuase on ebay I got 1ftX1ft metal sheets and they also make them bigger then that. instead of cutting out the whole floor board. Just a thought. Just keep a soft right pedal, pretty soon your windsheild will come off. LOL
You can't weld alm. to steel , I hope you know that. Alm. will melt before the steel starts to heat up. You need a steel plate. Look on ebay their pretty cheap.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostYou can't weld alm. to steel , I hope you know that. Alm. will melt before the steel starts to heat up. You need a steel plate. Look on ebay their pretty cheap.
I know where your talking about the place where they use the lift spots at. Just use a dremel in that area so you don't cut it up. I have had grinders get away from me before costing me cutting through a good muffler.LOL Plus the sparks that come off the grinder are crazy.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
hey stever, can you post me a link to the little metal sheets you get?Team NoVa
ok...so we tried both TIG welding and MIG welding metal pieces to the floor pan...not working...we're burning through the floor before we are getting the weld...we dont have access to a welder for awhile now...so we are thinking of fibreglassing the floor where we cut the rust spots out...anyone see any issues with this?
Originally posted by flamingchicken View Posthey stever, can you post me a link to the little metal sheets you get?
http://cgi.ebay.com/1-8-FLOOR-PLATE-...item2a0225400c08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....3 days ago
