stupid parking lamps - FirebirdV6.com/CamaroV6.com Message Board
  • stupid parking lamps
    For those who have aftermarket clear parking lamps? Have you had problems getting in humidity or water in these laps? I have tried my best being sure the sockets are well connected but without success. It looks like humidity and/or water is getting in more from the markers than from the signals. I have heard someone saying that drilling holes underside will solve it. It looks stupid to make holes to something that was bought new. Any commentary will be very well appreciated.
    Camaro99\'3.8, original spoil package (no body mods...PROUDLY), K&N, Lid 3800II, SLP CAI, Flowmaster, Z28Chrome Tips, 180* Thermostat.
    Re: stupid parking lamps
    boris, ive got the same problem with my clear turn signals. Drives me ****ing nuts haha, im debating ditching my halos and turn signals cause they are just starting to deteriorate...
    Robby
    2001 Chevrolet Camaro 3.8 V6
    |JET Chip|Flowmaster American Thunder|K&N Intake|BMR STB|Spohn Rear Sway Bar|
    http://speed-bros.com/
      i have the same problem with my clear turn signals too. its so annoying cause i love the way they look. its seems like one is getting better but its probably just the weather. i was thinking about maybe sealing them up with something, dum dum or like liquid weather stripping. i feel your pain lol.
        From where do you think the water comes in?
          The point is, from where the water comes in. Knowing that, it'll be easy to seal the lamps.
            I don't really know. I know on mine the little outside bulb socket doesn't twist all the way i've been thinking about covering that with something.
              I tried with a wrench, and the socket turned more. That helped a little, but not at all.
                hhhmm im not sure maybe the housing itself then. i'll let you know if i try anything with them. i might put a small bead of like silicone arounf the whole thing and see it that makes a difference.
                  I have them... They suck :(
                  I want stockers with some VHT NS
                  98 Camaro 3.8 M5 Y87 | 99 Camaro LS1 Z28 T56
                    I seem to be one of few that have never had problems with this. I say run a thin bead of silicon around the edge of where the lens meets the body and get some foam washers for the bulbs. I didn't do any modification and they work fine.
                    Anyway, you won't hardly see the holes if you drill them in the bottom, and they'll allow water to drain instead of fogging up.
                    1996 Chevrolet Camaro
                    1995 Buick Park Avenue Ultra
                    --Appearance Moderator--
                      yea im savin the holes for plan B, if sealing them up tight doesn's work out
                        Sorry if I don't understand you. Do you say that you never had problems (no water, no fog) without the recomendations you give us? or you never had problems after you did one or more of these recomendations.
                        Did you or anyone tried the holes, and after that the innerside of the lamps stayed always dried (no fog, no water at all)?
                        Thanks. I'll think and try something else too and let you know what happens. I really like how these lamps look. I prefer to dump the halos I have than the parking lamps.
                        What's this?
                          We have a multiquote button ;) just click the ["+] for all but one of the posts you want to quote, then hit quote on the last, and it will quote all.
                          In response to your question, I have not had any problems with fog or water, and have never had to do any modifications to my lights. However, it's obviously a sealing problem of some sort, and running a bead of silicon around the lens and using foam washers would eliminate the possibility of water seeping in. I will note that I have foam washers, although I believe it's a factory thing and everyone should have them.
                          I have heard of several people that had great results from drilling 2 or 3 tiny holes in the very bottom of their corner lights.
                          And VHT NS is VHT (brand) Niteshades. It's a spray can of tinting paint, used to tint automotive lights to appear black but still light up normally.
                            Great information! Thanks! About the foam washers, where do they go?
                              They go at the base of the bulb and seal the socket to the light housing so no water gets in. If I had to guess, that's the most likely spot that water would get in, and the foam washers eliminate that from happening. In fact, it's really only necessary on the 3057 bulb.
                              • Andy H
                                Transmission removal help!!
                                by Andy H
                              • 2.8 Bird
                                Abs inop
                                by 2.8 Bird
                              • fishin
                                by fishin
