Hello gang. I've never removed the front bumper on our cars. How hard is it to remove the front bumper? I'm about to be installing a Blinder M27 which is a LIDAR transponder (aka jammer). This requires for two "heads" to be installed into the front of the car. I'm looking to put them into our bumper in front of the black camaro (stock) grill. I'm also considering just mounting into the grill too so we will see what I end up doing.
Removing front bumper.
Re: Removing front bumper.
A flat screw driver, possibly pliers, 8mm, 10mm and 13mm sockets should do it. There are a bunch of 10mm bolts which connect the splash guard to the bumper, and several 10s and a few 8s that connect the air dam to the splash guards and make the process easier, although it's not necessary to take the air dam off. Take the 4 or 5 clips on the top between the headlights out as well as the 4 or 5 directly underneath these accessed from the bottom in front of the air dam. There are I think two 10mm and one 13mm on each side connecting the fenders to the bumper, and on my car there are a couple 8mm bolts holding the headlight area to the car, I'm not sure how yours will be but the rest should be the same.
Check out this link.
http://www.bfranker.badz28.com/fbody...er_removal.htm
OneEightSeven join Team RED!Robby
2001 Chevrolet Camaro 3.8 V6
|JET Chip|Flowmaster American Thunder|K&N Intake|BMR STB|Spohn Rear Sway Bar|
http://speed-bros.com/
