This is my first post, so I hope I posted it in the correct thread. We have a basically stock 95 Camaro that has bad tail lights (one has a crack/hole in it and the other has water in it). I decided to buy a new set of after market lights on Ebay (black, Altezza) brand since they look pretty good and are cheaper than what I can get as far as originals. I received them today and they look pretty solid.
I plan to swap them in the next few days. It is my understanding that it is fairly easy job, but on some Ebay listings it said that professional installation recommended - a warning sign maybe some tweaking needs to be done. I took a quick look from the inside of the trunk and it doesn't seem as simple as pulling back the carpet. Do you have to remove the inside side panels too? I would appreciate any advice from someone that has done this before. Thanks in advance!
