Just leave it out to dry and make sure the rubber gasket by the bulb isn't jacked up and if need be replace it.
#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
I looked around and whenever i saw posts about this issue, it always seems to be the passenger side light. It must be something about how that one was made that causes it to leak first.
I solemnly swear I am up to no good.
2008 Saturn Sky Red Line - Midnight Blue Pewter Mafia - 2000 Firebird - SOLD CENTRAL FLORIDA KNIGHTS!!!!!!! FLORIDA STATE SEMINOLES!!!!!!!
That was actually a broken tail light I had taken off for example. :P
It can sometimes be the pass side, but... I used to have a set that had been dimmed and siliconed too late after the damage had been done.
Water gets inside and somehow makes the reflective coating on the inside turn black and w/out that there useless. Poor design or $ making deal for GM I dunno. But these are sure expensive in good, bright RED condtion.
Same thing happened to my Camaro lenses this Spring. I noticed the tail light lenses on both sides were damp on the inside. The tops of both lenses had separated from the casings enough to let water in. A little silicone sealant and they were good to go.
8 hours ago
