K will corvette c5 rims the thin 5 spoke ones fit on my 96 camaro? please let me me know, if i need any thing like spacers or something or if they will just bolt right up. please let me know soon. if so im getting some friday
corvette C5s 18in
Re: corvette C5s 18in
depends on your tires honestly. and the rim width, some are 18x8 and they should fit fine.Wait, Is that a V6 or V8?
Originally posted by ACiFiC View Postdepends on your tires honestly. and the rim width, some are 18x8 and they should fit fine.
Originally posted by TheGr8Schlotzky View PostSounds like an awesome deal to me assuming the tires are the correct size. If they are 9" wide, 275/35/18 will be the correct size, or 245/40/18 if 8".
here they are
What are the tires ? then we can tell you if there going to fit, if the guy takes a tape measure and measures the tirre width that tells nothing. Need the tire width and offset off the rims. If it was thread width my back tires would be 12"s and the 335's are 13.5"s. Also since you have a 96' if you haven't done it yret you need to grind down the rear hubs for newer rims.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostWhat are the tires ? then we can tell you if there going to fit, if the guy takes a tape measure and measures the tirre width that tells nothing. Need the tire width and offset off the rims. If it was thread width my back tires would be 12"s and the 335's are 13.5"s. Also since you have a 96' if you haven't done it yret you need to grind down the rear hubs for newer rims.
enough for the clearence, probably be pretty obvious how much you need too, hard to describe without having it in front of you.Wait, Is that a V6 or V8?
mine are GM corvette rims, those exact ones...I needed to grind the inner hub portion of the rim a little, and I had to hammer my inner fenders in for the rear of the car...I also added a 1/8th spacer, and replaced the all the studs with factory replacements (I did this because the orignal studs have a nipple on the top with no thread, so you only get like 5 turns with the lugnut, but the replacements are 100% threaded, so you get 10 turns)
For the grinding, I just used a dremel with a sanding bit. About 5 minutes each wheel will do it. I did a little to the hub and a little to the wheel.
Techsan, chances are you had to beat in the well and remove the bump stops because the tire is larger in diameter than stock. I have 275/35/18 on 9.5" corvette rims and needed no modification other than the hub grinding.
Originally posted by TheGr8Schlotzky View PostFor the grinding, I just used a dremel with a sanding bit. About 5 minutes each wheel will do it. I did a little to the hub and a little to the wheel.
I have since added a 1/8th spacer to give myself a little extra room as well...
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 day ago
