you can get 17 x 9.5 that will will fine on a 2001 just depends on your tires.
Wait, Is that a V6 or V8? 1990 Chevrolet C-K 1500 series 4.3L .. 5spd
1994 JDM Euno Roadster 1.8L 5spd Bolt Ons.. etc 2000 Camaro 3.8L Auto Bolt Ons..etc
Hi, thanks for the responce,
but i don't want 9,5" wheels, if the 17"x8" wheels fit, i can use the 245 tire, with a 9,5" wheel, it has to be a 275.
I have a 3.8V6 Camaro, and i don't like a 275 tire on a V6 Camaro, it's too big.
these arent for your car, like said above i dont think the backspacing is right on these.
275s arent that big.... I think the only wat you can find a 8inch wide zr1 rim is if you get the limited zr1 wheels that came on slp camaros from like 95-97. I had a set for my firebird, they were 16x8, grey, with polished lip.
hi, thanks for the responce,
My Camaro has the original 16x8" snowflakes, with 245/50/ZR16 tires.
this size of tire is rare in Europe, Goodyear and Michelin has a tire that will fit, but they won't sell it in Europe, only in America.
If i switch to 17x8" wheels, i can use 245/45/ZR17, and this is a regular size of tire.
what??? the bigger the wheel the better. Small tires make a car look weak. 275's look so good from the rear.
You need to find out the offset of those wheels in order to verify if they will work or not. Email the company or see if you can find it online. Acceptable offsets for an 8" wide wheel on a 4th gen would be around +38mm to +56mm.
13 hours ago
