Seat Belt Torx Bolts - FirebirdV6.com/CamaroV6.com Message Board
  • Seat Belt Torx Bolts
    After searching on here and the web, I just wanted to post the correct information for anybody that might need it in the future.
    One of my rear seat belts needed to be replaced. Research showed that it was a Torx T-47 bolt. That is not entirely correct.
    The bolt was SUPER tight. The T-47 would have stripped. I actually found that a T-50 fit the bolt head exactly and I was able to pull on it like crazy to break it loose.
    Hopefully, somebody can use this information in the future.
    Re: Seat Belt Torx Bolts
    i would also recommend getting a set of torx sockets that fit on a ratchet.
    the seatbelt bolts are tight for a reason and one of those multi-torx tools is just going to bend and twist.
    im against harbor freight tools, but i have a harbor freight set made by pittsburgh tools that hasn't broken yet.
      I totally agree. I used Torx sockets and pulled VERY hard on it to break it loose.
        I usually tap them in with a hammer then use a 6" extension on the ratchet for leverage.
          I have stripped the seat belt bolts before. That is good info, thanks for sharing!
            I second the tapping with a hammer first. This seems to break the rust and factory locktite loose. Also I use Torx sockets and a breaker bar to get them started.
              3 days ago
