hooking up air/fuel ratio gauge... - FirebirdV6.com/CamaroV6.com Message Board
  • hooking up air/fuel ratio gauge...
    How do I hook one of these up? I was told by a friend that it needs to he hooked up to the o2 sensor... so I want to know if it needs to be spliced or something... if more info is needed ill get it tomorow.
    #1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
    Re: hooking up air/fuel ratio gauge...
    Electric or wideband?
    Wait, Is that a V6 or V8?
      I think electric but I don't know...how would I tell?
        If you're just getting a gauge, save your money. It's pointless to take a signal from the factory narrowband sensors. Invest in an actual wideband from Innovate, NGK, etc. That will give you useful data to make adjustments via tuning software.
          Well I already have the gauge. I most wanted it to monitor my o2 sensors. Im assuming its not a wideband cuz I don't really know what thatis but I googled it and it doesn't look like what came up lol I just wanna know where to install wires... to the o2 sensor?
            Yes, you can tap into your factory narrowband 02's, but the data will do you no good. All it's going to give you is a laser light show of leds.
              Which wires do I splice into? I rink there's 4 on the sensor...
                it will be the one going to the PCM, which i think its purple or blue or something.. you can't return it and get the wideband? lol
                  I've had this gauge for a while I didn't just buy it.
                    alright, well i had an electric one for little bit, it was alright. but like i said. depends on the the o2 sensor you have.. mines a denzo and has a blue wire and that's the one i used.. but i switched over to an aem uego
                      Just hook up the 1 wire?
                        the gauge you bought probably has three wires coming off the back right? black red and purple?
                        • Andy H
                          Transmission removal help!!
                          by Andy H
                        • 2.8 Bird
                          Abs inop
                          by 2.8 Bird
                        • fishin
                          by fishin
