How do I hook one of these up? I was told by a friend that it needs to he hooked up to the o2 sensor... so I want to know if it needs to be spliced or something... if more info is needed ill get it tomorow.
hooking up air/fuel ratio gauge...
#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>Tags: None
Re: hooking up air/fuel ratio gauge...
I think electric but I don't know...how would I tell?#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
If you're just getting a gauge, save your money. It's pointless to take a signal from the factory narrowband sensors. Invest in an actual wideband from Innovate, NGK, etc. That will give you useful data to make adjustments via tuning software.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Well I already have the gauge. I most wanted it to monitor my o2 sensors. Im assuming its not a wideband cuz I don't really know what thatis but I googled it and it doesn't look like what came up lol I just wanna know where to install wires... to the o2 sensor?#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
Yes, you can tap into your factory narrowband 02's, but the data will do you no good. All it's going to give you is a laser light show of leds.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
Which wires do I splice into? I rink there's 4 on the sensor...#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
it will be the one going to the PCM, which i think its purple or blue or something.. you can't return it and get the wideband? lolWait, Is that a V6 or V8?
I've had this gauge for a while I didn't just buy it.#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
Originally posted by unvmyrs View PostI've had this gauge for a while I didn't just buy it.
alright, well i had an electric one for little bit, it was alright. but like i said. depends on the the o2 sensor you have.. mines a denzo and has a blue wire and that's the one i used.. but i switched over to an aem uegoWait, Is that a V6 or V8?
Just hook up the 1 wire?#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
the gauge you bought probably has three wires coming off the back right? black red and purple?Wait, Is that a V6 or V8?
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...2 weeks ago
