Hi, I have a 1997 Camaro, was wondering if anyone was experiencing or has experienced this, when you go to shut the door it seems to be a lot of excessive rattles and its never a nice tight shutting sound. Just wondering if anyone has done anything to fix this?
Excessive Door Rattle
Re: Excessive Door Rattle
could also just be the window slamming around. Take off the door panel and check for loose bolts, as well as the little brush things on the top of the door that push against the window.
My firebird, and then my camaro both rattled allot. Just took the time to adjust and tighten all the bolts and both were fine after that.
My driver door def rattles - the outer skin is not completely attached (was repaired when i got it which failed). I've attempted to epoxy the skin back on with limited success. With the driver window down it rattles. I should try bringing the latch in a little to try to get a slightly tighter seal around my passenger door as to not find puddles inside after rain.96 White M5 Camaro. Manual everything. Magnaflow cat, dynomax dual outlet axle back. Swapped to a disc rear with 3.42s and a torsen differential, kyb gr2 rear shocks, moog rear endlinks.
