Goo left by window tint - FirebirdV6.com/CamaroV6.com Message Board
  • Goo left by window tint
    I took of the window tint film off my back window on my 2k Camaro
    as it did nothing but obstruct my vision as the car is always hot as
    hell if it sits for more that 4 minutes in the hot Florida sun. Well the
    adhesive stays on the window and I have having a hell of a time to get it off. I tried a steamer...then I tried amonia...then scratch remover..then
    wd 40 then vasoline....anyone REALLY know what works?
    Re: Goo left by window tint
    Well. Take it to a professional. The only thing that works is a razor blade.
      I am getting that impression is that the only thing that works IS
      a razor blade.
        Use amonia on it should leave it with no resido. Do like a 10:1 solution with water.
          Sorry, it Amonia is not working in any ratio...even 100%
            Any solvent will "help" But you def need a razorblade.It is a total pain the a$$. I've used goo gone, alcochol, tint remover, and none of it really took it off...but it helps. It's wicked time consuming. Good luck.
              I've always used steel wool to get stuff off my windows. And it cleans them like nothing else too.
                I had to take my wint off 2 weeks ago because I got pulled over for it. I used a semi-rough rag and a whole lot of elbow grease to get the goo off. It got it all off but it is just a little exhausting to do. Also if you dab gasoline on the rag you use that seems to help a tiny bit.
                  Bought some liquid designed to do just that take off the film...bought at Walmart...it goes back if it does not work.
                  Found out that without the black film on the back of the Camaro
                  it does NOT heat up in side parked like it used to...the black
                  attracts the sun...then heat.
                    Originally posted by PalmHarbor View Post
                    the black attracts the sun
                    :slap:
                    I solemnly swear I am up to no good.
                      I've got no tint, and my car seriously gets like 120 if I leave the windows up all day, and I'm in Colorado...
                        Its because of the giant windshield and hatch allowing ridiculous amounts of sun in, plus even more if you have t-tops.
                        I had to remove tint when I bought my 94 bird, steam and some orange based solvent stuff, and elbow grease did the trick.
                          lots of glass cleaner and a razor blade thats the way i took my old tint glue off works good but time consuming
                            pain thinner worked for me. i forget the name of the other stuff my dad had me used that really took it off great but its realted to pain thinner and is sold right next to it a lowes. i just forget the name.
                              mineral spirits?
