Cover to add switches - FirebirdV6.com/CamaroV6.com Message Board
  • Cover to add switches
    Is there a way that I could add a "cover" to the center console to put switches in it? Like take out the little cubbyhole hole and put something there to add a switch and 2 leds for an idea I have?
    Sent from my Samsung Fascinate using Tapatalk.
    Re: Cover to add switches
    I don't know of anything commercially available that accomplishes that, but with a bit of fabrication, anything is possible. It could be as simple as a sheet of textured black plastic, dremeled to the correct shape, attached with a single cabinet hinge at the back and opened by a hole drilled in the front, or much more complex. Depends what you want and how much effort you are willing to put in.
    1996 Chevrolet Camaro
    1995 Buick Park Avenue Ultra
    --Appearance Moderator--
      I wanted to fabricate it myself. And I have all the time it takes. The only thing is this would be my first type of fabrication like this. So would you/anyone mind helping be out with maybe a little rundown?
        http://www.ebay.com/itm/330623126340...84.m1438.l2649
        Raven
          I don't have a manual or a trans am sadly. Also id rather fabricate it myself.
            6litereater might have something
            http://6litereaterdesigns.com/store/...cPath=21_37_56
            contact him or maybe you can use something of his.
              Wow. That website has like everything I've been wanting... thank you!:)
                That heads up display is kinda cool. Ah I wish I still lived with my parents, i had money to burn then..
                TEAM C6V6
                  I am living with my parents. Haha. But going to Med school isn't good for the money issue. :P
                    Like this?
                    http://www.ebay.com/itm/330623121438...84.m1438.l2649
                    Raven
                      Originally posted by FirebirdGT View Post
                      Yeah that looks pretty spot on. Just have to make sure no holes are in it. :P
                        dude i want that heads up display. but i want it to show KR, fuel trims, boost, iat. and "the office" love that show.. lol
                        but back to the topic at hand... how many switches are you talking about? i used a piece of 1/8" metal and cut holes in it for my switches and put it in my ashtray slot.
                          There would be one DPDT switch with two 5mm LEDs (at this point).
                          • Andy H
                            Transmission removal help!!
                            by Andy H
                          • 2.8 Bird
                            Abs inop
                            by 2.8 Bird
                          • fishin
                            by fishin
