180's are more fun when they are intentional. my brakes locked up in traffic today. I don't even remember slamming on them, just spinning around. i hit a car in the next lane but not bad. herself and her car were fine. just needed a buff. no police or anything thank goodness.
after
Its an easy fix. Its better than totalling the whole car.:banana:
Hit up harbor freight and get you some sand paper, on the way home hit up autozone and either get some fiberglass or body filler, do the work and get macco and your back on track like it never happened. ;)
definitely better than totalling the car. and its actually an easier fix than that. just rough up the area with 60 grit and use a hard file to make a groove where the crack is and fill with epoxy. sand the epoxy like its bondo. sand with 220. add primer, sand with 400. and i actually painted it myself so i don't hafta worry about a 50/50 paint job from macco
