Thought you guys might like this one (well some of you), others will probably just laugh lol. I went out and bought this the other day...got it for a steal, and it's about be my new favorite tool.
I plan on starting to shaving some serious weight from this car by getting a little creative.
I started today, although I only worked on a few small brackets and didn't use the hole saw yet, just a couple of drill bits. My goal is to shave 100 lbs through cutting/lightening parts, trimming unneeded wires, and shortening needed wires. So far I haven't removed much, cleaned up a few wires from things that were put in and left some excess wire. I managed to shave 2lbs today, so 98 more to go to hit my goal.
Here is what I worked on today. I took these brackets and drilled out about 8 holes in them. 3 of the holes were in the area that buts up against the window, I took the cloth off, drilled out, and replaced the cloth. The part that butts up against the window is damn thick!
Then I moved on to this bracket which is located behind the side mirror. Just filled it with holes!
