Lowered 2010-Present Camaro's - FirebirdV6.com/CamaroV6.com Message Board
  • Lowered 2010-Present Camaro's
    Some owners want to lower their Camaro's but don't know which setup to go with or how it will look. For any 2010-present Camaro owners that have lowered their car, please post photos below and let us know which setup you are running! I will be adding some photos below as well from some of our social media followers.
    Eiback lowered 5th gen Camaro
    eibach lowered camaro 1.5"
    This setup is on Eibach pro dampers and 1.5 drop springs.
    2015 Camaro Lowered
    This setup is a 2015 Camaro on BC coilovers 1.25” on Front 1” on rear
    2010 Camaro Lowered
    This is a 2010 1.5 inches front 1.0 inch back( progressive springs)
    2015 lowered camaro
    This is a 2015 Camaro 1LS with BC Coilovers
      Hurst Stage 1 lowered Camaro
      This is a 2010 Hurst stage 1 kit. 1.25” is the listed drop however popular consensus is that it drops more than that.
      2013 RS camaro lowered on BMR lowering springs
      This is a 2013 RS, with 1.25" BMR lowering springs.
      Camaro eibach lowering springs
      This Camaro sits on eibach lowering springs
      2012 Camaro Megan racing coilovers lowered
      This one is a 2012 Camaro on Megan Racing coilovers maxed out
        2014 Lowered Camaro
        2014 1LT 1.5inch lowering springs
          2011 Camaro Hurst Lowered
          This is a 2011 Camaro with 1” hurst lowering springs
          Camaro Lowered BMR Springs
          This Camaro has All BMR Springs sways and trailing arms. I believe their springs are either a 1.25 or 1.5" drop
          BC coil overs Lowered Camaro
          Lowered Camaro BC racing 2.5-3"
          This a 2017 Camaro is lowered 2.5-3" on BC Racing coilovers
          Lowered Camaro BC Coilovers
          This Camaro is lowered 4" front and 3" rear with the BC coilover setup
            BC coilovers Lowered Camaro
            BC coilovers lowered 1 1/4" all the way around on a 2010 Camaro
            2015 lowered BMR camaro
            This is a 2015 lowered Camaro on 1.2" bmr springs with 285/35-20's rims/tires
              Lowered with staggered big wheels look good.
                Wow , some of them are so low, how do they handle speed bumps?
                  A very stiff spring rate can do wonders
                    BMR lowered 2013 Camaro
                    This is a 2013 Camaro with a 1.2” drop on BMR springs
                    Belltech lowered 2010 camaro
                    2010 Camaro with Belltech 1.5" drop all the way around
                    2010 lowered Camaro dropped
                    dropped 2010 Camaro
                    2010 1LT
                    Rear - Stock (Need to roll my fenders before I can drop)
                    Front - Dropped 1" on Amazon springs (AJP Distributors Suspension)
                    Tires setup:
                    255/40/20 Front
                    275/45/20 Rear
                    2011 BC coil overs lowered
                    2011 Camaro on BC coilovers with a 2.5 inch drop
                      Camaro dropped
                      Lowered 1.6” front and 1.4” rear. 275’s front and 315’s rear.
                      Camaro dropped low
                      BC Racing Coilovers. Lowered 1.5 front, 1.6 rear. MMR Z28 running 275/40/20 on all corners...Eibach ProKit sway bars
                      H&R lowered Camaro
                      H&R lowered Camaro
                      H&R lowered Camaro
                      H&R lowered Camaro
                        Camaro lowered Eibach
                        Eibach 1" lowering kit
                        megan racing camaro lowered
                        Megan racing springs
                        bagged camaro
                        bagged camaro
                        4” drop on Airlift 3P
                          Lowered camaro
                            Lowered camaro
                            2012 V6 LFX. Air ride performance 3p management system
