Post a picture of your rims/tire setup on your 2010+ Camaro - Let us know what size rims and tires you are running and the offset as well if you know it!
2010+ Camaro Rims / Tire Setups
Project Cars | How To Guides | Scratch Repair | Synthetic OilTags: None
2013 v6, 20x9 30 offset rear, 20x8 30 offset front.. 275 Rear 245 front v8 brembo brake set up, hotchkiss springs trw wheels
2012 2LT RS, MRR 755 20inch wheels running (275/35/ZR20) fronts and (315/35/ZR20) rears
Petrol P1A 18 x 8.5
Offset 35, load rating 1700, weight 24. So all that's close to factory specs and you can reuse your factory tires.
Variant Xenon in Satin Black. 19x10 F, 19x11 R. Nitto 555 265/40/19 F and 305/35/19 R.
HRE FF04 20x10 275/30/20 front 20x11 285/30/20 rear with bfgoodrich comp2 a/s
Giovanni 20x9 with stock tires.
Stock Camaro rims with 50 mil spacersLast edited by LETZRIDE; 03-04-2020, 01:40 PM.
22" rims 245/35/22 on the front (soon to be 255/35/22 and 265/35/22 on the rear
20” Foose legends 20x10 40mm , 275/40/20 , 20x8.5 35mm 245/45/20
20 inch 295 in the rear 265 up front. Rims are TSW not sure the exact rim sizes though
Have 6th gen ss wheels front and back normal 245/35/20 and 275/40/20 in the back also tried the 1le with 315s in the back
20" rims - 245/35R20 front / 285/35R20 rear
