Its not simply about the wattage, you have to judge the light output in Lumens. It is easily possible for a lower wattage light to out put more lumens than a higher wattage light. It all depends on what color spectrum the light is emitting on. One part of the spectrum is going to be bright etc...
2002 Maple Red Firebird V6<br />3.73 w/ LSD | Pro-5.0 Shifter | Fan Switch | Tach w/ Shiftlite | Boost and Fuel Pressure Gauge | Bilstein Shocks & 1LE Springs | 1LE 32mm Bar & Poly Bushings, Poly Tranny Mount and Torque Arm Bushing | BMR LCA\'s | Catco 3\" Cat w/ Edlebrock 5509 Muffler, (all 3\") | Corbeau A4 Seats (Pair) |<p><a href=\"http://forums.fakeleg.com/\" target=\"_blank\">http://forums.fakeleg.com</a><br /><a href=\"http://cv6.fakeleg.com/\" target=\"_blank\">http://cv6.fakeleg.com</a> - Part & Repair Manuals and write-ups.
in short... xenon gas keeps the filament ( spelling? ) cooler... in turn will burn brighter...
( info below not to be used, just made up numbers for example )
75 watt halogen ( stock) 4000k on the "brightness scale)
75 watt xenon 6000k on the brightnes scale....
also bulbs with some krypton help also.... the best aftermarket bulbs i would go for are called showoff( may be spelled a dif way i cant remember)
I went through 3 dif types in my slowstang when i had it a while back.... by far showoff was the best...
Thanks Big Tymer! I figure anything is going to be an improvment over the stock firebird lights. Heck, I had motocycles that had a brighter single head light. LOL [img]graemlins/rofl.gif[/img]
I just bought the eurolight kit which is the same thing as auto optiks, except they send the female connector, and the Xeon bulbs as well. This way you don't have to waste time hunting other needed parts. ;)
It said it ships within 24-48 hours. So might get it today. That would be sweet! Wish I had a digital camera to get pics for you guys.
I would have gotten real HID from Tbryne, but crap... way too expensive for me. The eurolights / autooptiks is enough $ already. LOL
the K number is the color temperature, in degrees kelvin. ie, 4000K or 6000K
Lumens is the light output, and kelvin is the temperature.
you can get more output with a different lamp, but that has many variables. But most of the automovie bulbs are misleading advertising.
Ryan. <-- i know too much lighting stuff.
[ November 27, 2003: Message edited by: slow ]</p>
1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
<blockquote>quote:</font><hr>Originally posted by slow: the "brightness scale" is not the correct term.
you can get more output with a different lamp, but that has many variables. But most of the automovie bulbs are false advertising.
Ryan. <-- i know too much lighting stuff.<hr></blockquote>
How the hell does the light hit 6000 degrees K?
Yeah lets put a blowtorch in the front of my car!
lol sorry for the sarcasm, but that is a really high temperature... is that like the max temp it can operate at or something?
Glass is considered one of the oldest synthetic materials and consists of silica, sodium carbonate, and lime. Other elements are often added to this mixture for coloring purposes. Glass often begins in the form of a powder or sand that melts and fuses when heated. This sand is generally heated to a temperature of 1300 degrees C or 2400 degrees F, although the melting temperature of glass varies with its composition. Workable glass is generally the consistency of chewing gum, but by changing the temperature, the consistency can vary greatly.
<hr></blockquote>
Glass begins to melt at 2400*F... that's less than half of 6000*K
I am confused now lol
I have more, with my theatrical lighting stuff, let me find it, and i'll post it.
Ryan
