I just got my clear corner lenses , how do I attempt to instal these? Do I go from under neath the car or do I do it from under the hood? I don't have a lot of time to install these because I an going away so it would be good to know what I am going to have to do before I get started.
Thanks,
Buy the way I live in Canada and it's freakin cold
on the hands
In case its a 97- Camaro I'll tell the instructions now:
Take off the panels underneath the car, about 10 or 12 little bolts. The rest of the installation is basically right in front of your face. Before you tighten the screws on the new corners get out from underneath your car and make sure they are lined up on the outside.
Shouldnt be no more than 15min.....good luck
(install should be the same for all the other cars anyway)
