Now you can use a manual shift knob on automatic cars!
Ive had a manuel shift knob on my shifter for a year now...its not that hard to do...I put a carbon fiber B&M t-handle on...looks pretty good
later
[ April 16, 2002: Message edited by: Modifiedv6 ]</p>
Purple 1995 Camaro<br />Moroso CAI, Flowmaster American Thunder Cat-Back, Coated Pace Setter Headers with custom built Y-pipe, NGK Plugs, Taylor Wires, B&M Shift Kit, ASP Crank and Alt. Pullies, Hypertech 160* Powerstat, TB Coolant Bypass, Custom Manuel Fan Switch, 17x9 Mille Miglia MM11-2 w/ Kuhmo ECSTA Supra 712\'s, Too Many Appearence Mods To List <p>Suspension: Complete Rear Drum to Rear Disc conversion (3.42 Gears, POSI), Eibach Pro-Kit(1.25\" drop), BMR Strut Tower Brace, BMR Adjustable PHR, BMR Lower Control Arms, 1LE Front Sway Bar, SS Rear Sway Bar, 1LE Driveshaft, Energy Suspension Bushings All Around<p><a href=\"http://www.geocities.com/MotorCity/Shop/9233\" target=\"_blank\">My Webpage</a> <br /><a href=\"http://www.worldwidecamaro.com/cgi-bin/ultimatebb.cgi?ubb=forum&f=33\" target=\"_blank\">Birmingham F-Body Assosication</a>
if one were to do this, im assuming you dont have to press the button anymore to shift out of park or reverse??? so if you could tell me more about this and how it allows you to shift in and out of PRND321?? thanx
merlin
Ya for real...i want a shift knob with a button for the nitrous. that way i can hold on to something while i get my *** shot back into the seat. ALSO if it doesnt use the button how do you keep it locked into drive so it doesnt shift into park by mistake?
If that is the kit I am thinking of, you still push down to shift, only now you push the entire knob down instead of a button. The kit includes a spring and other mounting hardware. One issue in the F-body is the lack of a leather boot around the shifter to hide the new mechanism. The vette's don't have that problem.
