sanded one headlight down, one to go - FirebirdV6.com/CamaroV6.com Message Board
  • sanded one headlight down, one to go
    the one is looking pretty nice, ecept it still has tiny scratch marks from sanding, so i probably need to sand it down a little more
    Wow! Great job!
    http://www.cardomain.com/ride/2287597
    :( SOLD! NO LONGER A CAMARO OWNER :(
      good job. To get rid of the scratches try wet sanding it with really light sanding paper.
        nice improvement.
        Visit My F-Body Page
          Originally posted by Loochy88:
          nice improvement.
          thanks.
          looks alot better now, and i started the other one today.
          I worked on it for about an hour, and they almost match... but not quite.
            http://www.ls1tech.com/forums/showthread.php?t=157192
            we should sticky that or something. try some of that polish im sure itll make it look a ton better. hell even if it doesnt its only $12
            '99 Camaro Y87 M5 T-tops
            Flowmaster american thunder cat back, 2.5" magnaflow high flow cat, centerforce dual friction clutch
            Car Domain
              check the stickies, allready there
                Damn man, that looks nice.. You should do the whistler mod to your headlights...I have a pewter car too, and I did the whistler...looks absolutely sick.
                #1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
                  looks good.
                  Follow me!
                  Or this
                    looks good. if you use zaino on your car you can put layers on your headlights as well to protect them against discoloring. If you dont use zaino I'm sure there's something else you could try as well.
                      I have a 2000 and have always used special plastic cleaner and armour all on it and the plastic lenses are totally clear.
                      Phil
                        Thanks, Im pretty sure im going to do the whistler in the future. Also, my sar is sebring silver, not pewter ;)
                        Originally posted by vanbibber:
                        looks good.
                        Thanks [img]smile.gif[/img]
                        What kind of zaino stuff? I have been hearing alot about it, but never really looked into it.
                          humm, armour all?
                          Maby i gotta try that after im all finished, because when i have the plastic polish on them (before i run it off) they look REALLY clear and nice.
                          Im not looking to have mine perfect though, just better than they were before.
                            that looks good. My maro's headlights need that!
                            <a href=\"http://www.cardomain.com/ride/857214\" target=\"_blank\">http://www.cardomain.com/ride/857214</a>
                              dude that is looking good
                              WAWA-A-HOLIC
                              • Andy H
                                Transmission removal help!!
                                by Andy H
                              • 2.8 Bird
                                Abs inop
                                by 2.8 Bird
                              • fishin
                                by fishin
