if i sandblasted my rims....
I dunno, I found jewels and diamonds underneath mine. Too bad I traded them for crack...2000 Camaro, Pewter Metallic, M5 tranny, 3.23 gears, Hard Top, <br /><br />Modifications:<br />SLP loudmouth (dual/dual tips)<br />MSD 8.5mm wires<br />K&N airfilter<br />SS hood (don\'t buy from fiberglassfabricators.com!!!)<br />Spec stage 2 clutch
id recommend using paint stripper instead of sandblasting. youd have an easier job once the paint was off.
like i said, bare metal, when i painted my rims i polished the lip, i used ( like loochy said ) paint stripper. then used 800 grit, then work my way all the way to 2000 grit, then clear coated them. they were really shiney at 2000 grit, even with out polish. i didnt use polish assumeing clear coat wouldnt stick to it.sand blasting may be too rough, depending on what they use. theres alot of differet types of sandblasting, rubber pellets are used too, not just sand.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
i think there is a product u can buy, it's aviation grade paint stripper.
Im sure ive seen it talked about on this board before.... check it out, probably can buy it at pepboys to peel off the paint and then polish them.
Sandblasting them may leave a rough surface like loochy said*Matt
Originally posted by StrtRacer98:
if u stripped the paint, and they are aluminum, you would probably have to spend sometime polishing them to make them look good.
i wonder if i could pick up a cheap on from somewhere
stip the paint off, sand with maybe 1500 grit ( depending on how smooth they are after stipping then ) , work your way up to 2000 grit then use a aluminum polish. they'll look great. just time consuming.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
by FirebirdGTAll - sorry but there seems to be some glitches from moving to a new Host - hopefully they will be fixed soon.
If needed you can email me...1 week ago -
by LETZRIDEI am happy to announce that I have sold the site to Robert (FirebirdGT). Years ago this site went down when TealV6 had it, I bought it, refreshed it,...4 weeks ago
by LETZRIDE
Building the Tom Henry RS
Part 4: Suspension Mods, Tires, Wheels, Headers and other Cool Stuff.
By: Hib Halverson
At the end of Part Three, we changed the valvetrain of the 3.8-liter V6 in the Tom Henry RS. We installed new, Yella Terra "Ultralite" 1.8:1, aluminum roller rocker arms, Katech valve springs and Katech titanium retainers on our 3800 Series II V6.
Ultralites are nearly 25% lighter than the stock 1.6 rockers and 8% lighter than the SLP aluminum...02-07-2020, 11:30 PM
