Just Got My Trans Am Hatch, How Do I Install It? - FirebirdV6.com/CamaroV6.com Message Board
  • Just Got My Trans Am Hatch, How Do I Install It?
    I just got my Trans Am hatch in and I'm ready to install it, but the thing is, I don't have the slightest clue how to install it.
    I know I have to take off my stock hatch, but I dont even know how to go about doing that.
    I also have to put the plastic lining around the interior of it, so I have to take that off my stock hatch and put it on my Trans Am hatch.
    I need instructions on both, it'd be greatly appreciated.
    Summer:<br />1999 Black Pontiac Firebird Coupe<br />5-speed, T-Tops, Chrome Rims, TA Hatch, Reflective Decals.<br /><br />Winter:<br />2000 Silver Grand Am GT<br />Reflective Black Badge Overlays, chrome
    ill go outside right now, take pics and write up a full guide..... i just need to get up off my ***
    I guess I\'d have answer your question with another question.<br /><br />How many Abidiginals do you see in modeling??????<br /><br />headers, 3inch magnaflow cat, Loudmouth<br />99 Midnight Blue Firebird<br />3.8L A4
      Thanks dude, I greatly appreciate it. I'm ont much of a mechanic, and my dad doesn't know how to do it on a 99 Firebird.
      You know my MSN if the pictures are easier to send that way.
      Thanks again!
        ok......youll need two people to do this.
        -first thing you have to do is get into your backseat, and unscrew this
        -once that is unscrewed pull back the cloth/insulation and youll see a mess of wires.
        -locate this clip
        this is your third brake light, and defroster set of wires.
        -once the clip is disconnect begin to unbolt the 4 bolts that attch the hatch to the car. two shown here
        - your next task is to detach the hatch struts. these are really easy.
        - the easiest way ive found to take these of is to have a nail handy. all i do is insert the nail inderneath the clip of the strut, and gently lift up.
        as so:
        (make sure you dont take the clip all the way off, because they are a pain the the A$$ to get back on.)
          now that all the old stuff is detached you can lift the hatch off the car and set it down somewhere else.
          now time to install the new hatch. guide the hatch to where its supposed to be.
          -first bolt up the hatch (so you dont have to have it open the whole time.)
          -next you will have to guide this piece of rubber (dont know what its called) into position. this thing should have your third brake light and defroster wires/clip.)
          -there should be a hole/opening where you can guide the wires back into position.
          -attach your new clip to the correct place (where you disconnected your old one)
          again shown here:
          (sorry for being blurry)
          -once you have your wireing in place your should go ahead and re-attach your shocks. this time you shouldnt have to use the nail to lift the clip. they just slide back on.
          you now have your hatch onto the car. the next step will be installing the interior trim (if it isnt already installed.
          gimme a few to go take pics.
            now for the interior install (if needed)
            this is if you are taking the plastic trim off your old hatch and installing it on your new TA hatch.
            - on your old hatch start in the corner of the largest piece. get your fingers underneathe and slowely start to pull away. there are yellow clips or fasteners that hold the trin to the hatch itself.
            - once you have pulled the trim off you may notice that a few of the clips didnt come off.
            thats ok, go into your garage and get a pair of needle nose pliers.
            when removing these yellow clips it helps to give the a wiggle every now and then, cause they are tough as hell to get out. do worry if when you pull some out that they look fugged up, they are still useable.
            -the next part would be putting the yellow clips back into the interior trim. they are very simple to put in. they just slide in
            make sure you have all of the in there
            - reinstalling them is 10x easier than taking them out. just line em up with the holes that are left.
            before you install the large piece you should have taken all the trim out of your old hatch (i just didnt want to take all of mine out)
            and your done!
              this is a cool sight once yours is installed.
              a nice whale tail in your rear view.
              if you guys have any questions email me at
              snuffalofogus1@hotmail.com
                That makes me want to do it! haha.
                Helluva walkthrough, Snuff.
                \'96 M5 Camaro White<br />Flowmaster Full Catback<br />SLP CAI<br />180* Thermo<br /><br />Stereo: H/U - Clarion DXZ725 <br />Alipne Type-R 6.5 Components (front), <br />Alpine Alpine SPS-1629S 6.5 <br />2 10\" JL 10w0<br /><br />\"One Love\" -Bob Marley
                  Nice instructions Snuffologus, I just did mine recently.
                  After I installed the hatch didnt line up correctly and wouldnt close, I had to line up the bottom part for it to work.
                  But I just love the way it looks, I will post pics this coming monday.
                    And as Snuffalogus said, you will need 2 people, I definetly needed two people.
                    Snuffalogus doesnt ur hatch not stay open? Mine closes now after like 5 seconds.
                    And does you Trunk pop up in your keychain work?
                      Best instructiosn I've ever gotten, that's for sure.
                        yes my hatch does stay open (even with the firebird struts) it stays open for a good 5-10 minutes nowadays.
                        and my trunk pop thing kinda works, when i press the button it pops up a bit, but not like when i had my firebird hatch
                          This should be sticky or archived..nice write up bro, I'm thinking of getting one too. And with this at my disposal...I'm sure it'll be a breeze...
                          Check out my <a href=\"http://www.cardomain.com/memberpage/401661/2\" target=\"_blank\">Domain Site.</a><br /><br />The man who laughs last, is slowest.
                            WOW, that is an amazing walk through. Very thorough. Good job.
                              Hey Snuff. Copy and Paste it in to a new topic over in the Mod Review Section.
                              http://www.camarov6.com/ubb/ultimate...ubb=forum;f=30
                              Cardomain
