help polishing brushed stainless steal exhuast tips - FirebirdV6.com/CamaroV6.com Message Board
  • help polishing brushed stainless steal exhuast tips
    just like the subject says. The exhaust tips that came with my dynomax cat back are stainless steal with a brushed finish, I want to polish these suckers up. I'm thinking I'll wet sand them first with some 320 grit. I'm wondering how a wire brush wheel would work though, it did well on my brake calipers, but those are aluminum. Any advice guys? Oh, and I dont have a dremel, so no dremel attachments
    [ March 30, 2004, 08:49 AM: Message edited by: lifeguardinme19 ]
    98 White T-Top Firebird<br />w/ the crome 5 star rims<br />FRA, Smoothed stock lid,<br />Dynomax Super Turbo Exhaust<br /> <a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=346111\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=346111</a>
    I'm looking at doing this today after class, some help please guys?
      Not sure what you want to do, why not just stainless steel polish?
        Eagle One makes a wadding compound called Never Dull. It is in a little silver can, and is a cotton wadding you tear away. Works great!
          yeah, never dull works well at taking oxidation off I find, but these aren't oxidized, they have grain to them since they are brushed and I need to make them smooth. I guess I'll start with the wet sanding and then try the wire wheel brush, then move to polish. thanks guy
          [ March 30, 2004, 12:10 PM: Message edited by: lifeguardinme19 ]
            What I would do is first wet sand around 1200 grit to see how deep the brush effect is. If it is deeper try a 800 grit, then finish again with 1200 grit. If you are going to buff them by hand bring them to 2000 grit. If you have a bench grinder with the cotton wheel use some jeweler's rouge and the process is a lot easier, but be careful when using the bg because pieces that you are working will want to get away from you too. Also the wire wheel it tends to leave pits if it is to coarse.
            I have some pics at the below after sanding and buffing the brake lines and the homemade pcm cover. I have a feeling im leaving something out, but I'll fix it if I find out what I left out
            2001 Sunset Orange Firebird<br />V6? Nothing Special... Maybe?<br /><br />The Car: <a href=\"http://cardomain.com/id/sunsetbird01\" target=\"_blank\">http://cardomain.com/id/sunsetbird01</a><br />Other: <a href=\"http://community.webshots.com/user/sunsetbird01\" target=\"_blank\">http://community.webshots.com/user/sunsetbird01</a><br />The Owner: <a href=\"http://www.myspace.com/9788480\" target=\"_blank\">http://www.myspace.com/9788480</a>
              Oooh nice PCM cover. i just removed mine on sunday to get to the grommit to go thru the firewall and the plastic is cracked on top (i didnt do it) and one bolt is holding it in only cause the other one decided to snap off while i was unscrewing it. lol
              <a href=\"http://www.cardomain.com/id/maleet\" target=\"_blank\">1998 Silver Firebird</a> <br />Basic mods... nothing real special but it sure looks good!<br /><a href=\"http://www.maleetpobanz.com\" target=\"_blank\">maleetpobanz.com</a>
                thanks guys, I tested the wet sanding on the underside of a tip and found it too abrasive. so I figured the wire wheel would be worse and went striaght to buffing compound and a synthetic bugging pad on a buffer. Once I found the right abrasiveness compound ( had 4 different ones sitting around) it went smooth as heck. The only hard part was that the tips were on the car so it made it hard to get the big buffing pad around the dang things. I only polished the side facing out on the dual dual tips. Look great with my nicely polished crome wheels. I'm happy
                  Originally posted by wenbanfirebird01:
                  very nice! im doing that as soon as i get home!
                  Visit My F-Body Page
                    what did you use to posish those brakelines
                    no fate but what we make<br /><a href=\"http://www.cardomain.com/memberpage/748167/1\" target=\"_blank\">http://www.cardomain.com/memberpage/748167/1</a>
                      I used some type of sand paper my dad has. Its used for polishing metal, the only thing i can describe it as a screen. This is to get the haze off of it. Then I buffed it using a dremel with a cotton wheel and some tripoli rouge (the green one). If you don't wanna sand it you can go to a harder rouge, and I miss a spot in the pic. Thanks.
                      • Andy H
                        Transmission removal help!!
                        by Andy H
                      • 2.8 Bird
                        Abs inop
                        by 2.8 Bird
                      • fishin
                        by fishin
