Hey i need some help i'm litterally cutting the top pof another car and just welding it to mine as in a frame to b frame and walla i have t tops i'm paying 50 bucks for this. Brackets and all i need to get the glass and i think headliner if they havn't ruined it. Problem is will this work good you think. Also i'm payign 600 total i think in labor for a shop to do this if this works this guy will do ours he works out of ga
My t top mod
You don't need to weld anything on just cut off the sides basically.2002 M5 Bright Metallic Silver <br />*Fully loaded and modded<br /><br />2005 GSXR 750<br />*Micron Serpent Race Exhaust *K&N Filter *Power Commander *Trying to hit 200 MPH!<br /><br />1970 SS 454 Chevelle Cortez Silver<br />*It can pass anything but a gas station
exactly and there is a t-top kit out there to make your hard top into t-tops.
do a search here. A couple of guys has already done it. If you cut the top off your car copletely you will be making a huge and very DANGEROUS mistake.
The stock tops were made to be cut to create t-tops, but do not whack off the entire top ghetto style.
I've got detailed instructions and pictures in my signature from my t-top conversion project. The "Roof" is just a fiberglass top that's glued down to the t-top beam in the middle, and the 2 side beams, which are removed as part of the project. YOUR HARDTOP ALREADY HAS T-TOPS IN IT
Speed Automotive has a conversion "kit" that comes with everything you need except a headliner and windshield trim.
The one thing I MUST emphasize that you do is RESARCH RESEARCH RESEARCH! Know EXACTLY what you're getting into before you do it. THe link in my sig also has links to 2 others who have done the same project and which i used for a guide in doing mine.
Good luck!
-Mike
[ April 29, 2002: Message edited by: MTMike ]</p><b>Trucks</b> <br />\'05 Dodge 3500 Dually <i>Cummins Turbo Diesel</i><br />\'98 Dodge 2500 4x4 <i>360 V8 (Wife\'s)</i><br /><b>Toys</b><br />\'81 Chevy K10 <i>Stroker/Swampers/Custom Suspension/1-Tons/Beadlocks</i><br />\'99 Camaro Z28 <i>6 Spd, T-tops, Borla</i><br /><br /><b>Real trucks don\'t have spark plugs</b>
